Update on 968 Turbo Project
Posted an update of my 968 turbo project on YouTube. There are also a few other videos of other projects there as well. I'm hoping that public posts will help me to get the car finished in a timely fashion.
https://www.youtube.com/channel/UCg0...apZZQY27Sz0g2w |
Holy cow that's awesome!!!
Love the time lapse.
I assume the 5 speed is from a 944 and the ratios work better on the track? -Yogii AKA 968 Virgin |
Were you able to retain ABS with going to the early offset in the rear?
ABS Question
Originally Posted by sm
(Post 15576386)
https://cimg6.ibsrv.net/gimg/rennlis...d03ea1cd8.jpeg |
Thanks for doing that research and implementing the low offset “backdating”. What offset rims will you run out back? Did you go low offset for the front? |
Rear Wheels
(Post 15577367)
Thanks for doing that research and implementing the low offset “backdating”. What offset rims will you run out back? Did you go low offset for the front? For wheels, I had a set of BBS wheels made (9” front, 10” rear) to match the late/early combination. |
Very nice project! Look forward to seeing it up and running soon. What led you to the decision for the AEM Infinity? Just curious, as I'm still researching what standalone system to use.
AEM
Originally Posted by Ryan968
(Post 15578418)
at the time I purchased the Infinity,I had a tuner experienced in the AEM products lined up to handle the dyno sessions. |
That sounds like a good reason to me :) The computer is one of my big concerns with adding the turbo, making sure I have a good baseline to fire up with and then getting it tuned right. I'm not very familiar with any of them, and could see that part being a major pain. On my last build I just installed new chips- nice and easy!
ECU
(Post 15578739)
Originally Posted by 968gene
(Post 15578771)
check out the AEM website. Their box is based upon volumetric efficiency, so any upgrades to the engine won’t require a re-tune.
Looking super clean and well done Gene |
Originally Posted by boost feen
(Post 15646849)
Oh no that’s horrible I hope your ok and don’t forget next time when you wreck on the track to let go off the wheel !!! |
