TurboS2 9PSI dyno chart
We just dynoed our S2 Turbo conversion. This car is running 9:1 compression, custom rods, stock head, stock pistons, stock 951 exhaust, large injectors, ARCII MAF kit, pump gas (91), stock cams, stock chips.
The wastegate is stock and is very weak, so its getting replaced, it limited the runs to 9PSI, with terrible boost fall off on the top. We will be back on the dyno next week after the wastegate is installed.
http://forums.rennlist.com/upload/ashdyno.jpg
The engine will be tuned to run 1 bar of boost, and with the turbo we installed for this conversion we are expecting some pretty impressive results at that boost level. I don't want to specualte and pick numbers, but we expect well into the high 300's in HP and TQ at the wheels.
This dyno chart shows Torque at 310.8 at 4500 rpm. With Hp at 303.6 at 5700 rpm at 9 PSI.
