Parting complete 968 engine all FS:
1993 968 engine with spun rod bearings crank has good main journals but needs to be reground for use with porsche oversize oem rod bearings or offset ground for stroker build on all 4 rod journals with the Honda or Mitsubishi bearings! All other parts are marked for prices shipped to you and in good working order.
3 liter crank $400 shipped
Block is free for locals SOLD
Pistons have major scuffing SOLD
Camshafts great shape SOLD
Cylinder head w/lifters caps valve train SOLD
Variocam tensioner SOLD
Valve cover SOLD
Front timing cover 3 pcs $120
Upper cam timing gear & aluminum cover w/hall sender and parts $250
Fuel rail w/injectors $150
Dme computer never opened $250
Mass air meter $225
Wiring harness $125
Intake manifold w/ throttle body $225
Set of 4 great condition pistons SOLD
Exhaust manifold great $150
Complete gas tensioner timing belt tensioner setup for use on any 944 60k water pump interval anyone $350
Airbox with new k&n filter $150
Oil filter console w/oprv, oil lines & cooler which works but is bent a little SOLD
Oil pump complete $150
Complete box of hardware from engine teardown excellent shape $125
Porsche script fuel rail cover/trim alloy piece good shape $125
Valve cover SOLD
Mass air meter $225
Wiring harness $125
