Stalls...won't idle
Stalls...won't idle
I was out in my 968 and went thru a puddle that was deeper than I thought. The Car stalled but re-fired and I got out of the puddle and made my way home which was not very far. The car was running rough. When I got it in the garage I could hear that the cooling fans were not running. They always run for a few minutes after I turn the car off. I replaced both of the 25 amp fuses for the cooling fans, they were both blown. After both fuses were replaced, the fans came back on but the car still will not idle. Don't even know if the two issues are related. The car runs fine once she gets started and I can feather the gas pedal enough to keep her running most of the time, but at idle, she always wants to stalls. Once you get her going, she runs normally. Where should I start trying to figure out the idling problem? Appreciate any suggestions. Thanks
