968 Forum 1992-1995
ambient temp gauge needed
Old 09-15-2017, 11:14 PM
walts62ragtop
walts62ragtop's Avatar
Default ambient temp gauge needed
Looking for an ambient temp gauge for my 95 968. Seems to have power, but screen doesnt work. Anyone have one?
Old 09-16-2017, 06:35 AM
968workaholic
968workaholic's Avatar
Did you pull the gauge out and check the backlight bulb? The screen will not illuminate if the bulb is bad
Old 09-16-2017, 08:29 AM
walts62ragtop
I have not pulled it. I didn't know there was a bulb. Thought they were led screens.
Old 09-16-2017, 11:38 PM
biosurfer1
biosurfer1's Avatar
Yep, tiny bulb back there. They are LCD screens, not LED.
Fyi, the screen is attached to the trim with plastic clips, make sure you unhook both to remove the screen, if you only do one, the other tab will break. Don't ask how I know😒
Old 09-17-2017, 09:01 AM
walts62ragtop
LCD is what I meant, sorry. Is the bulb like a dash bulb? And if the bulb goes out, how would it stop the screen from working? If I press on the screen lightly, you can get some sort of image to appear, but it might be accurate. And goes away as soon as you let off.
Thanks for the reply.
I'm just trying to figure this out a bit before I go an take apart my car. You know, have a game plan.
Bill
Old 09-17-2017, 07:07 PM
Paul Waterloo
Paul Waterloo's Avatar
The bulb is like a dash bulb. Mine had the same issue, and when I took it off for something else, I was able to just wiggle things when it went back together and it all worked. No replacement bulb needed.
Old 09-23-2017, 02:07 PM
hb253
hb253's Avatar
How involved is it to change the bulb? Does it require dissassembly of the dash or does the temperature display pop out somehow?
Hugo
Old 09-24-2017, 05:40 PM
walts62ragtop
From what I've read, need to take dash panel out...
Old 09-25-2017, 09:45 AM
Paul Waterloo
It's not hard....just go to Clark's Garage and there is a procedure there. You work from right to left, start on the outboard side of the dash to remove the trim and take a couple more screws out and you might have to take the glove compartment out, which is easy. When you put everything back together make sure you don't knock the rubber tube off the back of the air inlet vent for the HVAC system. Or if you do, just put it back on. Also, be very careful with the circle trim piece on the face side of it, it's easy to break when rotating it.
Old 04-21-2018, 09:24 AM
walts62ragtop
Default All good info...
Thanks for all the good info. On gauge replacement. Going to tackle this soon....when weather gets better.
Quick Reply: ambient temp gauge needed
