Just got this 964 turbo.
I have just bought this 964 turbo 3.3 (1991 ROW model)
I love it, and it´s my first 964. It drives really well, but I have a problem with missing warring lights.
The clock works and all the warning lights in the clock works as well. So I guess it´s not the bad clock problem.
(When I turn on the ignition at the last position before starting the engine all 3 lights are active and after a few seconds the airbag light turns off. When starting the engine and putting on the seat belt all lights goes off)
BUT, this is what lights up at the two first gages (also ignition at the last position)
works:
• The ABS warning light works and goes of after starting the engine.
• The brake pressure warring light works and goes off after the car has build up pressure.
Missing:
• I am missing the oil pressure warring light (point 1), just below the oil level gage, right ?´
• I´m missing the big warring light on the top of the gage? (point 2)
• Missing some warning light in the bottom of the gage? (point 3)
Here would you start? UPDATE: IT IS NOT the bulb's
Thanks in
BTW, Rennlist is an awesome site – best regards from Europa
works:
Missing:
Thanks in
Welcome.
Pointer #3 is for the parking brake. If it's not working there is a switch under the console cover that contacts the parking brake lever when the lever is up. You can bend the contact up on the switch to get it working again.
I don't have a wiring diagram handy but I'll look up where the oil pressures light gets a signal from (I'm not even sure mine's working).
