965 3.3 Idel ajustment question
Hey guys
I have plenty of experience with m y old 3.3 turbo, But not with the 965 3.3, very much the same but with a few controllers doing some of the adjustment for me, My 965 starts perfect warms up perfect, runs perfect ,
At cold start she goes to 1100 rpms, the goes down to 750, I would like to rise the RPM's to 950, because I like the sound track better at higher RPM'S and it helps with scavenge oil pump for the turbo.
Question...... is if I just bump up the idle to 950 will it mess with my tune, I don't think it should but what do you think ?
thank you
Helio
thank you
Helio
You adjust the idle on a 965 the same way you would on a 930 or a 911SC; with the idle bypass screw on the throttle body. It will have no effect on the "tune".
If you turn the screw and nothing happens then you have either a vacuum or air leak in the intake tract.
That's what I thought, But I just want to have someone else's thoughts, Thank you
All Done with no issues, set at 950, Went for drive .. all good
