964 Turbo Forum 1989-1994
No spark
Old 05-20-2017, 05:35 PM
maverick
maverick's Avatar
Default No spark
So I was having the LSD and shift linkage repaired and now the old girl has decided not to start....appears maybe the EZ769 ignition module is bad and of course it's no longer an available part.....anyone else come across this and have a solution?
Old 05-20-2017, 07:48 PM
Metal Guru
Metal Guru's Avatar
Check the plug for the flywheel Hall effect sensor first. It plugs into the EZ.
They have a bad habit of disintegrating.
heliolps2 (07-22-2023)
Old 05-21-2017, 01:25 PM
maverick
maverick's Avatar
Thanks Paul, yes he replaced the old crumbling one last week......strong signal now but no spark.....
Old 05-21-2017, 09:07 PM
mitchy965
mitchy965's Avatar
wild *** guess if the pick up is new.....turbo control module .
Old 05-22-2017, 05:32 AM
John McM
John McM's Avatar
If it is the unit, read my thread https://rennlist.com/forums/964-turb...trol-unit.html
Old 05-22-2017, 10:17 PM
maverick
maverick's Avatar
Thanks John, I remember following that thread......my issue is it won't start as in no spark.....we have a donor unit coming to help trouble shoot.....ill keep thread updated....
Old 05-23-2017, 04:57 PM
Metal Guru
Metal Guru's Avatar
The turbo control unit should actually be called a safety relay. It enables spark and fuel when it gets a signal from the flywheel hall effect sensor.
If you need one for troubleshooting I have one.
Old 05-23-2017, 08:32 PM
TT Surgeon
TT Surgeon's Avatar
Doesn't the vendor ' ecu doctor' rebuild the ez69 unit, or perhaps permatune?
Old 05-24-2017, 05:02 PM
ECU Doctors
Former Vendor
ECU Doctors's Avatar
I wish I could, but we don't repair those units.
There used to be a company in Germany that did so, but last time I asked them they told me they were too busy for that kind of work.
Old 05-27-2017, 05:00 PM
ralt
ralt's Avatar
COIL?
Old 05-27-2017, 09:44 PM
Metal Guru
Metal Guru's Avatar
Originally Posted by ralt
COIL?
Easy to test that.
Old 05-27-2017, 10:45 PM
maverick
maverick's Avatar
We were able to confirm its the ignition controller ......
Old 05-28-2017, 11:24 AM
Metal Guru
Metal Guru's Avatar
I have a feeling that whoever was working on your car fried your EZ through carelessness.
It's too much of a coincidence when something like that happens.
Old 05-28-2017, 11:36 AM
maverick
maverick's Avatar
All that was being worked on was the LSD and shift linkage so not really anything on the electrics side.....however for the last year it's had intermittent RPM issues with the gauge going dead arbitrarily and bouncing all over. We had replaced the sending unit last year and it seemed to help for a bit but still had erratic readings at times.....
I saw in an old thread that Cobalt had a couple of spares for a 3.3.......hoping he might still have them
Old 05-29-2017, 03:18 AM
TT Surgeon
TT Surgeon's Avatar
Oklahoma foreign or LA dismantlers may have a decent used one.
Quick Reply: No spark
