Mod or not
Mod or not
I like the car. It makes the right noises (with bypass, hehe). I love the 964 look but wife and I have a hard time fitting in.
Let me ask you all. Should I mod it?
Rims, it sits too tall and it should have speedlines or similar knockoffs.
Seating position, awkward. Need a steering wheel closer in.
Seats, too high. Need something lower.
Transmission, geared too high. Need lower 2d gear.
Is it worth making a bunch of changes or should I just get a 997 pdk?
And these mods still won't make the wife happy I'm sure.
Trucker
If you can work it, keep the 964 and buy a 997TT and enjoy the "modern" features. But they also need "improvements"...
If you need 997TT advice PM me.
I'm at the point where I'm going all out to make it livable for me or I'm going to get something newer. Status quo is not happening. I like Paul's mods.
Whatever you do, make sure it's easily reversible (except for the powertrain stuff, obviously).
My son and I are both over 6 feet tall, wear a XL suit coat (we're wide up top) and don't bump shoulders in my Turbo, so how much room do you really need?
Sounds like most of your complaints are regarding the body positioning in driver seat.
Rim changes are easy & reversible.
Tranny gearing also not that hard (assuming you have a good Indy tranny guy), and can be an expensive change (esp if you decide to sell & want to change back again),... but also reversible. So that seems it could be lower on the priority list.
It sounds like the #1 issue & priority for you would be the Steering Wheel Column - I am not aware of adjustable (telescoping & tilt) aftermarket available for the 964T. Tackle that first.
Since your list is not an easy one, and you have personal decisions to make, based on difficulty, cost, availability, and reversibility - I kinda agree with Dan. If you are not married to the 964T body style (which may trump all other), and you are really a performance guy,... seems it would be a lot easier to move to a newer platform.
=Steve
=Steve
If the steering wheel needs to be closer, there are aftermarket solutions that can move it toward the driver.
It's been a very long time but, I think I used a "raised hub" from some model 944 to address the steering wheel position. Someone will probably jump in with the specifics.
Gary
Gary
It sounds like the newer platform is calling you.. could not go that direction myself, but a very personal decision.
My experience with 964 mods:
Ratios: swapped 2nd-5th ratios much tighter (stock tranny). Single biggest difference to the performance of the car IMO (car never off boost once on it).
Cat/Muffler combo: easy to swap/swap back, can be tricky to get the right combo of sound/performance without being obnoxious. Sports cat + swans neck my favorite combo.
Headers/HF turbo: difficult for me to isolate the impact here above/beyond ratios+exhaust. If I was to do it over, I would do ratio's and exhaust first.. and evaluate from there.
Suspension/wheels: lower ride height and RH/speedline derivative is non negotiable IMO. Car looks so much better.
Seat position: I'm 6'4 and have the seats mounted on the lower mounting holes and it is comfortable. Difference of 1-2" if I remember correctly and an easy change.
Steering wheel: swapped to smaller nicer porsche wheel. Easy and relatively cheap change.
Hope this helps..
Hope this helps..
