PSS10 installed on Turbo 3.6
I am extremely happy, its been a year since I've owned this car and now its "perfect"
It appears the stupid folks at the dealership had the timing set advanced at +12 and now its at +3 and when you shut off the engine it sounds smooth. The dealership even cant follow the book guidelines.
The car needs final detailing and then the "Turbo 3.6" logo gets installed and I pick it up tomorrow for the car to be taken to Michelin for a allignment. I opted for RS spec settings but it appears to be too low "stance nation" in my cars case. I'll get it aligned dial out the front negative camber and want some negative camber in the rear.
I might have the front raised by 1cm and the rear 2 cm.
Today the Bilstein PSS10 are installed, they look awesome there peaking out the brake discs.
I just did shocks and eibach springs on mine (Koni FSD) RS is way too low for here. I ended up at 20mm below euro height and it works very well. 145mm if I recall Standard is 165.
"It appears the stupid folks at the dealership had the timing set advanced at +12 and now its at +3 and when you shut off the engine it sounds smooth. The dealership even cant follow the book guidelines."
Is your motor stock? What timing are you referring too and how is it adjusted? I'm assuming you're talking about spark and not CAM timing.
If the distributor is removed and re-installed at the wrong spot the timing will be off. The rotor has to align with the notch on the distributor body when #1 cylinder is at top dead center. I believe the spec is <0> +/- 3 degrees.
