F/S 3.2 carrera intake manifold
3.2 Carrrera intake manifold includes:
Fuel rails
Throttle body
ISV
injector harness
perfect EFI conversion ..These are getting scarce .
Elliot
$725 +shp
Fuel rails
Throttle body
ISV
injector harness
Elliot
$725 +shp
Hi,
92 Turbo is perfect for EFI upgrade.
I done this and can tell you the car comes alive especially in the low RPM range .
Fuel economy increases ,and Turbo lag is minimized .
the only question is how much power you want to make. The present CIS is very limited. So you scrap it. you need an ECU ,ignition module and coil, injectors, and some sensors, and lines and a wiring kit.
The intercooler you have is good , as well as the fuel pumps
The best thing I think is to call me I can tell a lot more if we talk.
In the evening is best.
Elliot
203 613 8000 cell
Elliot
203 613 8000 cell
