Should I be running away from GT3s ?
#31
that is it, we had an original, sold it to a customer, then we just started to modifiy them instead, also works on 964 with lfw for stalling....you will need to modify the bellhousing of the trans for it to fit....vinnie
#32
Thanks Vinnie. I had read a bit on the topic on pelican parts definitly something to check out.
However I am not sure net net what it does to engine longevity on a track car. Having it a bit late is probably safest even if it means combustion is not as good ? I m really clueless.
Keep in mind it's track only.
#33
Vinny, help me understand how this mod works.
Generally, retarding ignition closer and closer to tdc increases power. That's why twin plugging is preferred: the flame front has a shorter distance to travel with twin plugs, allowing ignition even closer to tdc.
#35
I searched but couldnt find it, would like to learn more
#37
one thing that we don't do on stock configuration 964 turbo car's is set of the ignition, its done through the famous control unit in the engine compartment, when the car comes on boost, the control unit backs the timing out if the car for safe running, have found that more boost, it wants to take more timing out of the motor, porsche seems to be very conservative in making power though the ignition control unit. you can easily add a little timing with the modification. it won't let the control unit take so much timing out on boost. if you own a car with a euro fuel system and only .9 bar of boost, this works great....i run a special built garrett turbo....vinnie
#38
Here are the charts from his car and the numbers appear to be quite similar.
#39
Rennlist Lifetime Member
I have to say that with these mods that the cars should be close in the HP department but the TQ should be more than the GT3 and the range should be lower on the powerband than the GT3. TQ is what should pull on the car and HP will sustain it. I have driven many GT3s and they are gutless on the TQ until the upper RPM ranges which the turbo should have already pulled on.
#40
You have been missed and your input always insightful. Hope things are improving for you.
#43
Believe it or not it is a dedicated race car used in the most grueling conditions. (high heat & high humidity) I am surprised he hasn't blown that engine up several times over. Although I haven't spoken to him recently.
#44
does that car have a euro fuel system and how much boost does he run??? at this point, very fine tuning plays a big factor...well tuned car, dialed in fuel system, good pumps, good power to pumps, hopfully not much blow by, not running dirty air back into the motor, fine tuned timing, the list can go on of course...
#45
I have been told by so many that CIS cannot support these numbers but I know he did don't know what life he got out of it.
