Who's Running 235/40-18's in Front? Any Issues?
Here is my procedure for installing the stops. Title should be Steering Stop: https://rennlist.com/forums/964-forum/454455-tie-rod-removal-steering-swap-installation.html
I've been recommended to roll the fender lips as well. Mine rub when I hit something such as a speedbump while turning. I need to roll mine.
I am running them in MPS2's and although I was not aware of it until I removed my front wheels this past weekend i have the slightest rubbing against the front inner shield apparently only when I make hard turns at slow speeds. Nothing I am concerned over and it is not doing any damage other than making a shinny spot on the plastic shield.
