computer boxes under passenger seat
i need help. i got a 91 turbo the previous owner clipped everything under passenger side seat. i got the factory amp together and the one to the seat. but there are two more. one has a yellow plug. can anyone please tell me what is there. any if possible give me part#. i think one may be an airbag computer and the other the cruise control module. i've called several dealers no help and several independent shops no help. anyone that can help me much appreciated.
Pictures would be very helpful to help you out.
I can tell you there is no factory cruise control on 964 turbo's.
The unit beneath the passenger's seat has some boost control function, and maybe an alarm or central locking function, if I recall correctly. If you remove that unit, the car won't run properly unless you rewire around it. I have tried.
I could be wrong on what it does, but you can't just unplug it and be happy.
this is what i have going on a yellow plug which i have been told is for the alarm system and a cut set of wires which i don't know if it goes to anything. i have been told also it is an extra set of plugs that are just there. thanks for your help guys any info will be valued.
hi,
the yellow plug (15 pins) belongs to the alarm/ central locking system, which can be identified by part no. 928.618.260.00.
the second plug on that controller is a black one with 26-pins.
fritz
fritz
