Another oil leak thread, plus a valve adjust question
Found oil leak I was worried was a cylinder base. Any reason this would blow out, apart from just an old o-ring? Oil pressure reads normal ranges.
Regards valve adjusting on our cars - can it all be done from underneath? I'm thinking the top valve covers may be hard to get to, so I was planning to do it while I've got the top of the motor disassembled to replace alternator and fan bearing, injectors, vac hoses, spark plugs and fix this oil leak, etc. But if it can all be done from under I may save that piece for later.
Anything else I should replace / check / clean while I've got access up top?
This is pretty common failure with these engines. I can't tell you how many people I know who paid for a full top end because their mechanic claimed the leak was more serious. Usually it is the washer/gasket at the base of the oil pressure sending unit but hard to tell it might be the oil temp sensor. Although I have seen on earlier cars where the oil temp sensor fails and it leaks out the top where the metal is crimped around the plastic top. Yours seems to have a ding or impression. You may consider changing all the gaskets and sensors while your at it just to be safe just be careful not to drop anything into the openings. It is cheap insurance vs pulling everything apart again.
Valve adjustments are a PITA with the engine in the car. Since you have it apart you might pull the side tins and have access from both top and bottom to do the top.
You could just replace all the seals in that area - AKA Triangle of Death - or clean it up and do a couple drives and locate the exact source.
Typically the intake valves get adjusted from the top - some disassembly required to get decent access.
Brandon
'91 911 Turbo
Brandon
'91 911 Turbo
Thanks guys - yes I decided to replace every sensor, sender and seal in the area (6 of em!). Couple of them were not cheap! But, I do like insurance. Will also do valve adjust while she's apart getting all the rest replaced.
I've done valve adjustments both ways (engine in and out of the car). I prefer engine out
Use the backside method to adjust valves. Here's a thread that Brandon and I were talking about it on: https://rennlist.com/forums/964-turb...ng-valves.html
WORKED THIS OUT - THE PET IS A BIT OFF HERE. SAME #40 ON MINE AS IN THE PET FOR 3.3.
There is one questionable sensor part number issue - sensor #40 on this picture - the diagram shows it only for the 3.3, but my 3.6 definitely has a switch there...hmmm which is it?
