Best Oil Cooler upgrade
Thank You
So I finally got back into a 964. Out of all the different 911 that I have owned this model is by far my favorite. This will be my first non turbo 964 (92 Carrera 2). I am looking to upgrade the oil cooler as summer is now upon us here in Texas. It is hot! Please give any suggestions that you might have.
Mike
Mike
This one
http://www.carnewal.com/products/P64.../GT-Oil-Cooler
It installs behind the factory ac condenser.
Thank You
This one
I dunno.....
Ad says it mounts in front of AC condenser. Do you really want to pre-heat the AC exchanger ??
Technical Guru
I would wait and see how the existing cooler functions. Even in 100F degree heat these tend to do just fine except for when sitting in traffic at idle for extended periods of time.
When the CCU detects a fault with the oil temperature sensor, it will automatically switch the oil cooler fan to high speed mode. You can take advantage of this by installing a switch that will turn the fan on @ high speed and more than cover any cooling concerns that you have.
Keep us posted!
Congrats on getting back into a 964.
Didn't you once own a Signal Green 3.6T? What a car, can only imagine what that car is worth now.
+1
Good advice, I recently had mine cleaned too.
They were clogged and looked horrible!
I would wait and see how the existing cooler functions. Even in 100F degree heat these tend to do just fine except for when sitting in traffic at idle for extended periods of time. And even then...
Good advice here. Also, be sure the current cooler is clean. Likewise make sure the cylinder cooling fins are clean. Unless someone has done that recently, I'm betting they are not. After you are sure of that, monitor and then see if you need additional cooling capacity. Most likely not needed once all is back close to "as designed".
Keep us posted!
Keep us posted!
several DIY instructions out there. I did a own kit with a heavy duty cooler and some dash hoses and fittings for small amount of money. I replace the ac condenser (AC removed) and works very well.. also at hot track-days...
the stock cooler works fine in 100 degree temps for street use. IF YOUR FAN IS WORKING! My fan trigger was nearly 270F and just too hot. Fixed that with the resistor mod, and wired in a manual switch.
The extra oil cooler is there for track days. The stock system struggles after 20-30 mins.
Oh, and the AC works fine.
Thank You
Thank You
Thanks for all the replies. I was sitting in traffic for a while and the oil light flickered on and then went off when I started to accelerate again. Since then I heard that this is normal in hot conditions. It was very hot at least 100 degrees and I was sitting for 5 minutes every now and then for 30 minutes. Usually I don't drive the car in traffic like that but can't remember ever that happening in the turbos I used to have.
Former Vendor
Mike
Mike
We add an additional cooler in the middle only for complete project build/restoration project since the front tub needs to be modified a bit for correct airflow. also the spare tire will no longer fit in the space after. We think for additional cooling that's the best option. just a bit labor intensive.
Make sure the cooler is free from debris, make sure your oil thermostat is working properly, make sure the bumper sealing wedges are intact to force air through the cooler rather than around it, and do the resistor mod so that the fan keeps the car at or under 9 o'clock when idling in traffic.
SA Mike: To date, what is the hottest temp you've observed and under what conditions?
