1997 Boxster will not shift into 5th Gear
Hello, I'm a newbie who's 1997 Boxster will not go into 5th Gear. Recently purchased with 90k miles. I've read the various posts, but no luck. Fluid appears fine and no disconnections noted under at transmission or with console removed. Car was driving fine, then out of the blue no 5th gear. Any suggestions would be much appreciated. Thanks so very much!
I'm sure somebody knows the answer in the right forum.
You are in 911 964 forum (produced between 1989 and 1994) Good luck! |
