Front differential 964
Just rebuild the front differential .
When adding oil before installation it did start leaking front the seal at the drive pinion .
Seen there is a cavity between the shaft seal and locknut i'm confused wether it is normal or not.
Looking forw for your feedback.
Partially. When i do put oil in the gearbox and kept level it should keep the oil . In my case i does flow from the lower part of the shaftseal
I did trey to add a picture but get always error
