964 Forum 1989-1994
Another part number Q
Old 05-19-2017, 06:43 AM
GeorgeK
GeorgeK's Avatar
Default Another part number Q
In the process of dismantling the doors pre-repaint, one of the female connectors in the mirror plug let go.
Would anyone know the part number for this connector, or know of an alternate source?
Pic pilfered from Google:
Old 05-19-2017, 08:38 AM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
How many conductors or pins is it? PET has a list of electrical connectors in section 9. But some of the connectors are only available as part of the wire harness.
Old 05-19-2017, 08:59 AM
GeorgeK
GeorgeK's Avatar
Actually, I *think* the single pin connector is available on PET, but there are several references, and I hope someone has gone through it already.
I only have one pin (actually the female half) that broke.
Old 05-19-2017, 09:03 AM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Are you looking for a replacement of a pin or the plastic connector?
Old 05-19-2017, 09:21 AM
GeorgeK
GeorgeK's Avatar
I was not clear enough. A single pin broke off from its wire.
Old 05-19-2017, 09:30 AM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Can you measure the diameter and length? There are 12 different replacement pins listed in PET. See 902-50.
PS: Do you have PET? If not, its a very handy reference.
http://www.porsche.com/usa/accessori...artscatalogue/
Old 05-19-2017, 09:50 AM
GeorgeK
GeorgeK's Avatar
I'll check that tonight.
Thank you.
Old 05-19-2017, 05:20 PM
GeorgeK
GeorgeK's Avatar
Edit,
This is what I need, but can't find the reference for on PET:
https://www.brickwerks.co.uk/electri...et-female.html
The female connector has an OD of 3.5mm. That is the one I need.
The corresponding male connector has an OD of 1.6mm.
Can't seem to find the corresponding part in PET (?)
Old 05-19-2017, 05:29 PM
Ken D
Ken D's Avatar
Appears to be an off-the-shelf Molex connector, you should be able to find them at any electrical reseller. This appears very similar - check the gauge of the wiring (AWG) to confirm. More results here.
Old 05-20-2017, 02:01 PM
GeorgeK
GeorgeK's Avatar
Found it: N 017 562 4
Old 05-20-2017, 05:01 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Quick Reply: Another part number Q
