Battery fitment code
Hi,
Looks like my battery has decided to call it a day
Does anyone know any fitment codes for the correct battery for a '91C4? e.g. a Bosch one or something? None of the useless shops around here have listings for Porsches and I don't fancy being robbed by the main dealer...
Cheers,
Dave.
Cheers,
Dave.
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Dave,
You need to max sure you get one with 72-74 amp/hr capacity. Nothing less. There is no real fitment guide as long as you get the capacity correct. Cabs need 88 amp/hr,
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
Registered User
i got a 74 last week from german , swedish and french , 47.50 plus vat .
but i might be taking it back now adrian has pointed out that its the wrong one for a cab !!!!!
i looked at bigger bosch amp ones but they where massive , not sure they'd fit . whereas the 74 fits perfect
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Ian,
The roof will kill off a smaller capacity battery. Porsche recommend the 88 amp/hr simply because of the roof.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
Hi Guys,
Thanks for the input. I bought a new 74A/h battery last night and the car seems much happier. Even the PDAS pressure warning beeping thing has gone when I start it Just have to hope now that there wasn't a problem with the charging circuit...
Cheers,
Dave.
Cheers,
Dave.
Adrian,
I thought I had the biggest A/hr I could find to fit, a Banner 80A/hr. Where could I get the bigger flavour? everyone else is physically too large to fit.
I think the fitment code, for bosch anyway is an 096, but that may apply to others a well.
Kevin
Kevin
Registered User
me too !!!!!!!!!!!!
i bought bosche because i used the silver top before , but it looks like i'll have to find another make !!
any other suggestions for a big amp battery that fits ??
anyone using the yellow ones that car stereo owners use ?
thanks
ian
thanks
ian
Originally posted by warmfuzzies
Adrian,
Kevin
Adrian,
Kevin
Ian,
My BANNER battery is good, Austrian build, they do OEM stuff for Audi amongst others. 4 post top so orientation is easy, 80A/hr. Calcium filled, sealed for life, and I mean sealed, it is welded shut....4 year warranty and all for £58. I'm only using the porker about once a week, and have not had an issue starting yet.....(oh dear that's probably done it)
Kevin.
Kevin.
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
I am afraid I cannot tell you what batteries you have available. Obviously Bosch make one because Porsche fitted it. I know Saentis herein Switzerland have one as well. Used to anyway. I would advise you check with Bosch.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
