driver's door mirror removal
What do you need to know - to remove mirror there is an Allen head screw ( on base at window side ) you must loosen to allow clamp to slide backwards far enough to pull mirror off.
I can send you pictures of mirror interior. There is a circle ring that locks the mirror itself in place. It has clip in fittings, there is a tang on the back bottom of the mirror that needs to be rotated to remove the mirror face. Kind of hard to explain, I used a screw driver to slide the tang to the side, was hard to move.
