Rear spoiler stuck up.
Hi All,
Sorry if this has been covered before.
So wanted to take the 964 out for a spin the other day, I had actually put a new battery in the car. However when I tried to start it the engine was just turning over and not firing.... I filled it up with a gallon of fuel, it worked fine.
However I noticed that the rear spoiler was up. Now I thought perhaps it was something to do with car having lack of petrol.??
I've checked the fuse number 37 and it's fine, the spoiler will not go down manually either.
What do you guys think??
Cheers
Sunil
Cheers
Sunil
The spoiler not going down wouldn't have anything to do with lack of fuel. It could be jammed you could unplug the spoiler drive motor and put 12 bolts to the plug positive on one side negative on the other for one direction and switch them for the other that will show you if the mechanism is ok
Cheers
Sunil
You can lower the spoiler by hand if you can't lower it electronically by disconnecting the drive cable from the motor and winding it down.
Have a look at the switches that detect maximum up and down for the spoiler. These sometimes need cleaning and adjusting. They can be found under the plastic cover over the gear mechanism.
Was your spoiler down when you last drove the car or had you left it up? If the limit switches are having issues the controller would not know when to stop it on the way up or down and it could be jammed up. The controller also could be having issues has your spoiler always worked? There is a lot of info on this site and the internet do some google searches and you should be able to find the info. What year is your car? 89 and 90 cars have 2 different controllers or relays 91 and up have one. On the 91 an up cars they are above where your feet would be on the passenger side small grey box about the size of a pack of cigs the earlier car they are under the passenger seat
Generally if the spoiler controller is having issues, the spoiler will still go up and down with the manual switch. So if your fuse/relay is OK, then your issue is likely in the mechanism itself.
