Noise limit @ Brands Hatch?
I'm considering going along to the PCGB Track Day at Brands Hatch next Wednesday. My car has a drilled Air Box and a G-Pipe (Secondary By-pass) fitted. Will I be over the noise limits?
Thanks!
Thanks!
Location: WhippetWorld, .........is it really only this many
1 Post
The noise limit at Brands Hatch is normaly 106db ( at least it is with Easytrack) and assuming its the same with PCGB you should be under this -just. I would check with PCGB for the noise limit. BUT you will be running close to this limit - most standard 964 struggle to get under 100db and I recorded between 100 to 105db ( different days - same venue)with just a cat bypass.
Its best to get the car tested in advance if possible.
I don`t think the noise police are over zealous at Brands - and remember clutch in, bring the revs up slow and 4k
