Rear seatback bolt removal ??
Has anyone tried to remove the bolts that hold the rear seatbacks to the body ? The ones on my car now have a bit of corrosion on the surface for whatever reason and I ordered replacements from my Porsche dealer but cannot get the old ones to budge ?? I figured a big flathead screwdriver would work as the bolts have a big slot down the centers of them. Regards, Brady
Registered User
big flat-head with means of attaching a spanner (unless you have a vice-like grip and arms like king-kong)
i used a snap-on with a nut-like shape just below the handle , which meant i could put my weight behind the driver , and turn it with a 13mm spanner .
or you could use an impact driver
