Homemade head – cylinder gasket???
Hi there,
I’m in the process of a top end rebuilt due to a head stud failure.
My car is from 1991 and have not the updated head to cylinder gaskets. No failure sings at this point. 145.000 kms. Running perfectly.
If I’m not mistaken, to do the gasket upgrade, I need cylinders and machine the head. This is not possible at this point (primarily due to budget).
I have two options:
- Mount the engine as it was, with no gasket.
- Custom built a gasket with some resistant material (for example exhaust gasket material).
Please, I need some ideas and opinions on the options or alternative ideas.
Thanks!!!!
I have two options:
Thanks!!!!
I replaced broken head studs on my MY91 and for similar reasons used exsisting cylinders and heads and have no leaks at the heads. I think Steve Wiener (spelling ? ) At Rennsport modifies exsisting heads to hold a gasket but doesn't modify cylinders that might be a route you could go
Might consider spending up for ARP studs if your not doing the gaskets.
JP-"S" (10-08-2023)
Thanks all of you for your kinds inputs.
I’m just thinking on a better way to make sure no leaks appear in the short term.
By Rennsport you mean the workshop at Barcelona (Spain)???
About the stud, I actuality was looking at ESP ones, but will also looks at the ARP. Any differences?
OK, because there is one in Spain also called Rennsport, but I doubted that that was the one.
Sending head from Spain to USA is probably not worth it.
About the head studs, there is so many opinions over the options that it’s impossible to really find out which s the best option, or at least I am not able to.
These are a commonly used upgrade. I am sure you have a local equivalent.
http://arp-bolts.com/kits/ARPkit-det...?RecordID=1194
Steve is in portland oregon - rennsportsystems.com but I would imagine if you make sure the mating faces are very well prepared and mated (by an engineer) you can achieve the original P design of max surface mating for heat transfer and no leak .. I went with steve's approach with 993 rings he supplied me to ensure no leak or blowby, and used a thin layer of the wurth/loctite 574 orange hitemp RV gasket sealer.
Dont worry about it. To hear the Internet talk about it, a car without the head gaskets is a leaking mess, and it just isn't true. Of the many potential places these engines can leak, the head to cylinder surface is waaaaaay down the list.
Actually most of these early 3.6's leaked like a sive. It is a matter of time with the early engines. Although You can rebuild the top end without the major expense and rework it to factory spec with some improvement and I have seen some of them last a long time without leaking. It is a chance some take.
Head gaskets always get the blame for dripping oil on early engines, but dripping OIL is a sure sign it isn't actually the head gasket leaking. Engines get rebuilt, head gaskets get added, along with sealing every other surface, and the leaks stop, so it must have been the head gaskets.
If someone wants to spend the money, I guess it wouldn't hurt, but lots of other places I would prioritize, especially in a situation like the original poster, who indicated the expense was important.
abarthguy (10-17-2023)
50.000 km ago I have had a broken stud.
Replaced al studs with 993 dilavar studs, no gaskets and now still no leaking cylinder-heads.
As wrote before above here: oil leaks will not come from leaking cylinder to head surface...
