Need HELP on removing longitudinal slave cylinder porsche 964 c4
Hi Andrew - I am having this very same issue and wondering if you can share details of the wedge you made or bought and how you went about completing this operation?
Rus
Rus
I used a wedge between the fluid port (highlighted) and the flange to separate the slave. Several taps with plastic hammer, lots of wiggling and it finally let go.
If you look closely you will see a flat spot on the fluid port where I had the wedge placed.
Thanks!
Andrew
Thanks!
Andrew
For anyone searching - I made a tool to allow the slave to be rotated to crack it free after which it can be pulled/pryed out. I'm going to donate it to Rob Goughary's Garage that it may help future C4 owners...
JasonAndreas (01-27-2020)
Impressive! Going to have another crack at removing mine today.
