Reuse caliper mounting bolts
My 90 C-2 has 58k miles on it. Rebuilding the front brake calipers. Seeing some discussions on other sites on reusing the caliper mounting bolts. Mine appear to be in good shape. Can they be reused? Does anyone know if these are considered one time torque use bolts? Also, the use of loctite blue is recommended quite a bit on other sites. Agree? Disagree? Lastly, optimoly HT lubricant. Found a thread that said should he lightly used on the guide plates which I have cleaned up. Anyone know where to buy it or an acceptable substitute? Thanks much.
Optimoly HT is basically "copper antisieze"- so any automotive store will have a suitable replacement. HT is "high temp".
The bolts are re-use. And there is a curvy lock washer that sits behind the head of the bolt. I've seen a few cars where these are missing.
Clean the threads in the upright and on the bolt, use the antiseize as prescribed in the manual. Torque is something like 63-65 ft/lbs. can't remember - but look that up and all good. If you are missing the lock washers, replace. Make sure if you don't use oem that there is some corrosion resistance- yellow zinc cobalt plated is how the oem are...
I seem to remember reusing mine when installing plastic bushings in my C2's front A-arms.
And before that when installing new disks at all four corners?
I don't recall using loc-tite. (Though in hindsight, a little of the blue would've been nice insurance, I guess.)
But that's just 'shade tree' experience.
I'm looking forward to what a pro has to say.
Technical Guru
You can buy Optimoly (HT/TA/MP0/3EP/ETC) from any Porsche dealership. There are other cheaper substitutes however most will effect the torque applied to a fastener, which is (i'm guessing) one reason why it has always been specified by Porsche. Obviously on the spring plates it won't make a difference. But for fasteners you will have to calculate a new torque specification.
Thanks much. Jason, is there anything I can or should put on the current bolts that would alleviate the corrosion issue on a re-use basis but would still be acceptable from a safety + torque standpoint?
I just did a major refurb on my brakes. I decided that my 20+ year old caliper bolts were ready to be replaced. The threads were looking a bit worn but still holding well. They aren't necessarily cheap.
Greetings Apanossi. FYI from my other thread I went with new discs up front. Still trying to get the rear calipers off. Do you know if those bolts can be picked up anywhere?
My local dealership
Never heard of Optimoly. I had to give them the part number and they didn't carry it. Had to order it, which I didn't. Hoping to find some locally real quick. I want to keep pushing this project along. It's drive time in AZ.
Technical Guru
If you plan to work on your 964 it so much easier to just order the right stuff in the beginning from Sunset Imports. And forget about the urge to drive around and try to source anything locally (especially from the local Porsche dealership). The prices are probably cheaper and the quality will be a huge improvement. Especially when it comes to things like fasteners, just forget about the hardware store variety. The thickness of the corrosion coatings is almost non-existent.
LOCTITE 8150
MOLYCOTE GN PLUS
CHESTERTON 725
Agreed
I would like nothing better than to have all I need up front. It's been a learning experience. Things like Optimoly, re-use of mounting bolts, the lock washer etc more or less came up after my original research and parts order was done. I just kept researching and these things popped up. Like anything in life, experience always helps the second time around. Thank goodness for you guys! Do you use Sunset because of price? I've been using Pelican.
IHI KING!
Nickyv, you describe what we all go through when we take on a project on our 964s. Sometimes, it's hard to come up with a definitive list of what you will need. These days I will "over-order" parts for a project and send back what I don't absolutely need. That way, you will not have to wait another 2-4 weeks for factory parts to arrive just so you can finish what you were doing. After the first couple times I did this, I learned my lesson. You also save on shipping costs.
As for the Optimoly HT, just get yourself standard copper grease. There are various vendors for this...Loctite, Permatex, Liquimoly. AutohausAZ is a great source for some aftermarket parts and lubricants/greases/fluids. Here's a link to Liquimoly copper anti-sieze for under $7. Can't beat that. http://www.autohausaz.com/pn/2012 . Don't waste your money on the factory recommended greases/lubricants. Some of those don't exist in the same description, and in many cases, have been improved upon.
