C2/turbo swaybar droplinks vs RS?
Has anyone really compared the C2/turbo(96434307101/96434307201) front droplinks with the RS ones(96434307281/96434307181)?
What is the difference?
They're likely the same structurally but dimensionally I think the RS piece is shorter and it definitely has the bend in a different spot compared to the C2 piece. Not sure what the end goal was (i.e. create clearance to brake line, position swaybar differently in relation to rest of suspension, etc.).
I think the difference was due to the difference in the upright.
There are plenty of good aftermarket drop links on the market. One is as good as the other. Just decide if you want partly solid or solid with rod ends...difference is slight and you get just a bit more noise with the rod ends links
