Fixing ABS/PDAS warning lights
Hi 2000m2,
That's probably not an appropriate question for me to answer. I absolutely understand that some of us would rather borrow or share their tools and experiences. I also understand that some would rather not loan out their tools. My goal is just to make the ABS test tools available. There are way more cars that need access to these tools than my ability to produce them.
So let me ask the question a different way for you - Are there any C4 guys in the Bay Area interested in helping out 2000m2?
Michael
Michael
cme41 (08-29-2019)
Hi 2000m2,
Michael
Michael
My ABS and PDAS light would come on after 10-15min of driving. I replaced the bomb, pump switch, and bled the brakes... Still there.
It was fixed when I replaced both accelerometers. They detect aceleration and side to side movement, and if they are faulty the ECU cannot compute correctly and shuts down ABS and PDAS.
Thanks for the input. I just dropped my C4 off at a shop this morning. Will see what they come back with and I'll keep this in mind to mention it when I talk to them.
PDAS will not be shut down (all-wheel drive function will always be operational !)
if ABS is shut down, the ABS warning light comes on and at the same time triggers the PDAS warning light - of course, the complete brake system will still work (minus ABS)
Car should never be rolled on to rear wheels only Dyno! Smog check shops must have 4 wheel dyno or no dyno testing during smog checks! As he said, AWD all the time......
ETA: http://www.adrianstreather.com/docs/...overviewR2.pdf
Don't expect warning lights to tell you that the pdas or abs has a fault either. There are some invisible failure modes for each system. The tech is far from perfect.
yes
have that problem with my car at present
even one faulty ABS-sensor will trigger both warning lights
first thing I will do in the spring, is check the whole system with Michael`s C4-tester
https://rennlist.com/forums/964-foru...or-orders.html
Finally, going to pick up the car @ the end of the month.
Unfortunately, no luck fixing the warning light. The mechanic still thinks it's the ECU brain - so the only options from his perspective is to find a swap unit to test > validate purchase OR get it from the dealer (which should be warrantied).
I appreciate all the advice though, so I'm going to check all the grounds and power first and the connector/pins once I get this puppy home.
On a side note, I've been looking into documentation on the car. Though I plan to find a good mechanic in my area (SF Bay) I want to DIY as many repairs as possible, and ran into this book: https://www.amazon.com/Porsche-911-9...ds=porsche+964
Does anyone own or have used this and found it helpful OR have another source the recommend?
Thanks,
Kevin
Thanks,
Kevin
Kevin it sounds like you have done a lot of checking but i did not catch whether or not you tried
just unclamping the big pin connector to the ABS Computer [ in blue ] and spraying contacts with contact cleaner. Then clamp and unclamp a few times so the friction cleans off the pins.
Then spray and clamp it back down.
My 91 C4 sends up the christmas lights PDAS/ ABS every once in a while- mainly in warm or humid weather; not at all in Winter. Anyway, this is definitely the problem with mine and is not a big deal and easy to service.
hope this helps - these are wonderful cars.
... ran into this book: https://www.amazon.com/Porsche-911-9...ds=porsche+964
Does anyone own or have used this and found it helpful ...
well, it`s (one of) the bibles
overhere in europe the price is twice as high ... so you can`t go wrong !
@911S3.6 - do you have a recommendation on the type of contact cleaner i should use? Is it something that i can just find an home improvement or dept store?
Finally brought the care back to it's new home! It drove great all the way - this weekend is my project to check the contacts of the big pin connector + see if all the grounds/power is working OK. Any other recommendations on what to take a look at if those both are unsuccessful?
Before I took the car home, I opened up the connector - and it looks clean - no signs of erosion, water damage, or wear (at first glance).
Thanks,
Kevin
Thanks,
Kevin
Thanks,
Kevin
Thanks,
Kevin
By the way, where are you in the Bay Area? Do you go to EASY on 1st Sat or are you planning to the upcoming meet up/swap meet in SJ on 3/26? I do tinker with my C2 Targa every now and then, so it would be fun to meet up some day with our 964s.
Tony
SF, CA
