Clunking sound when reversing
I have a 964 that gives some kind of rather loud clunking sound when reversing. I have really no idea where it comes from. When going forward in 1st gear there is no sound. I don't think there was this sound before a big engine repair when I also installed a single mass flywheel.
Any ideas what to check to find out what is causing this?
Is your car a turbo ?
The G50 /52 trans does this when backing with wheel turning direction .it is the limited slip lock up ....normal some GM positraction lube addictive helps.
Elliot
Elliot
