964 Forum 1989-1994
964 MY differences
Old 11-02-2016, 11:59 AM
GoatFarmer
GoatFarmer's Avatar
I have 2 AC buttons on the HVAC unit in my 94 C2. Could this be a MY94 change?
94 C2 HVAC
Old 11-02-2016, 12:24 PM
Ale_72
Ale_72's Avatar
It's the 993 unit. I have the same (and mine is '91).
I guess it was broken and replaced with that one in the past.
The code on the unit start with 993.
Old 11-02-2016, 12:33 PM
GoatFarmer
GoatFarmer's Avatar
Is the wiring harness different? The air volume is greater when selecting the top button so both switches are wired in my car. Does your 91 exhibit the same behavior with the 2 button HVAC?
Old 11-02-2016, 12:37 PM
Ale_72
Ale_72's Avatar
Same for me.
Old 11-02-2016, 01:11 PM
Vandit
Vandit's Avatar
My MY91 has a pin style frunk light switch and round shifter box bushings.
Old 11-02-2016, 01:21 PM
Spyerx
Spyerx's Avatar
Received 1,844 Likes on 1,123 Posts
Fwiw my 91:
Has the triangle rear deck latch (not pin)
Has the pin for frunk light
Has plastic intake manifold
Climate unit has one ac button
Old 11-03-2016, 04:38 PM
cobalt
cobalt's Avatar
Received 2,294 Likes on 1,357 Posts
Originally Posted by Spyerx
Fwiw my 91:
There were a lot of changes that were made mid year 1991 some variations between cars will be seen. Do you have the added release cables?
I am not sure about the double button A/C in 94. My turbo has a single button but it is early production 94 it might have been switched late production. If you have a late production MY 94 it is possible they switched out the this as well. Can you tell us if you have the black striker plates and rib-less door seals?
Old 11-03-2016, 08:15 PM
Spyerx
Spyerx's Avatar
How can I check this?
Old 11-03-2016, 08:26 PM
Deserion
Deserion's Avatar
Per Adrian's book, some 993 units will work without wiring changes. Others need a little tweak. The top button is for "Max A/C" - fans on 4, recirc on, lowest temperature. That overrides whatever settings we're currently in use.
Old 11-03-2016, 08:33 PM
Deserion
Deserion's Avatar
My '91 is a September 1990 build:
Pin latch on decklid
Pin switch for frunk light
Red pull ***** for rear seat release
Old-style switch under glovebox door
Plastic intake manifolds
993 climate unit (per part number)
Taillight gaskets (per PET stopped end of MY1990)
Old 11-04-2016, 09:20 AM
cobalt
cobalt's Avatar
Easiest way is to look at the screw that holds the cables in place at the latch if there are two cables you have them. To access them in case of no release the cable is accessible through the left rear tail light and you need to remove the front left wheel liner and search for the pull cable above the A/C condenser.
So it appears the alarm system and light switches changed to the latches in late 91 or 92. I will check the PET for the answer to that one when I have a chance. I forgot about the change from the one large tail light seal to the two smaller ones.
Old 11-04-2016, 11:28 AM
GoatFarmer
GoatFarmer's Avatar
My car has the 2 button AC. I am the 3rd owner so I can't confirm if it is original. Build date is 9/93. It has ribbed door seals and black door striker with what appears to be white nylon insert.
I enjoy trying to solve these little puzzles.
Old 11-04-2016, 11:46 AM
cobalt
cobalt's Avatar
9/93 and late vin probably one of the few last off the production line for US 964's. It is possible some of the cars towards the end received the two button A/C unit. Do you know if the door seals are original? The striker plates are correct for being late production. Does your hood crest have black or gold lettering? Some of the cars i have seen with the smooth door seals spent a lot of time in the exclusive department before being completed.
Old 11-04-2016, 12:50 PM
GoatFarmer
GoatFarmer's Avatar
While I can't be 100% certain as I am the 3rd owner, I can say with confidence the door seals are likely original. All of the rubber inside and out on the car is pristine with the exception of a small tear where the driver's foot would drag across the rubber on ingress/egress . The car overall is in very good condition at 40K miles. Last 5 are 20355.
The hood crest has gold lettering.
Old 11-04-2016, 02:16 PM
cobalt
cobalt's Avatar
Very cool nice example no doubt. I think there is no way of knowing what cars received what parts. I can only assume they were using up what they had and moved on to some 993 parts towards the end like your striker plates. My friend mikes Bad boy1 car from the movie has black plates and mine has the gold chromate finish.
Since there were only 160 US spec 94 C2's and they grouped them with the vin numbers of the widebody C4's it is possible yours is very close to one of the very last C2's made.
Quick Reply: 964 MY differences
