Routing damper remote canisters into the cabin
As the title says. I'm wondering how people route mote canisters into the front boot or the rears into the cabin without having to cut huge holes in the body? I'd prefer not to buy quick releases, but will if it helps me avoid cutting 2" diameter holes...
Dry break connection.
In the front you should be able to just notch the upright area for the tubing. For the rears I would not cut a hole. Just mount in engine bay. If you had a dry break you could just drill a small hole.
If you don't want to notch the front shock tower there are plenty of rubber bungs in the inner wings that can be removed to mount the canisters in the frunk, they're only big enough to get the hose through so you will have to let the gas out, reconnect and recharge. It's only nitrogen and most motorbike shops will have the gear to do it.
For the rears I couldn't find a way to get them into the back without chopping so I could mount them on the cage so fed them up by the engine tins and into the engine bay.
thanks guys. Dry break is the "best" solution. Just trying to not spend the extra grand.
Porsche Mania - you have a moton set up with the old banjo bolts. You managed to avoid additional oil seepage when you disconnected / recharged the nitrogen? Is it a needle valve or another fitting to charge them?
