C4 values?
C4 values?
Hello all- Sorry if this question has been posted previously;
I'm looking for a comfort level on the value of a C4 I'm looking at.
'91 C4 manual with 70K miles. Original GP white on black. It is in fantastic condition outside, inside and mechanically. As for as I can tell it is a "needs nothing" example. It does not have stock 964 wheels. Maintenance history back to new. Enthusiast owned.
Whats the range on value with the limited info above?
Apples to apples, how much more value does a C2 bring? And why?
Thank you
Thank you
C2
5-10k like for like
Why? More enthusiast focused? Easier to maintain, less complication, more sporting, lighter, etc.
5-10k like for like
You'll buy a 70k c4 in today's market that "needs nothing" for 45k. They will be offered for sale higher.
Be careful of "needs nothing" as that is usually bs. It likely could be a great car, but we all need something. These cars are old. And if it doesn't need anything right now, it's about to need something. Example. A 70k car, likely has the original distributer belt, but that now needs to be replaced, and while you are in there maybe have the distributer rebuilt w new bearings....
If it really needs nothing- it's worth more, but most people won't pay up for a better car so many cars will trade around the same value, and the real value of the car could be massively different. If you look at the paperwork and determine how much preventative work and maintenance has been done, and how much of that is work you won't have to do, you can get an idea of how much over the general market you can go and still be safe longer term...
If you don't plan on keeping the car a long time...be more careful on the purchase price.
This is really the key - A really nice C4 could be a good buy anywhere between 45-55k, depending on how much preventative work has been done and what you're likely to have to do in the near future. I'm pretty sure that almost every 964 you buy today is going to cost you between 50 and 60k -- it's your choice whether you pay that total up front or split it between the previous owner and your mechanic.
45k is a solid figure for a C4 coupe manual with that mileage. I would not let mine go for any less than that. My car has some exhaust and suspension goodies that I am glad I did not have to pay for. Some people want a stock car, I get that.
This goes for all 964s, but look for the standard oil leaks. at 70k, I presume it hasn't had the engine rebuilt. That will most likely need to happen in the next 20-30K miles.
But for 45K at 70K miles in GP White, that's a nice buy.
Probably 90% of 964's that have had their engines rebuilt will have been done because of oil leaks and not due to the mileage - and some with very low mileages. If the engine is and remains leak free I don't see why a rebuild would be needed around the 100K miles mark, so try not to read too much into this issue as it's blown way out of proportion. A well maintained 964 engine will run fine way longer than this.
Clearly though, do a PPI and if it's leaking you should factor in the cost to fix this in any offer you make on a car.
I have a C2 now and had a C4 before. Whilst I do prefer the C2 if I was looking for a 964 and a good C4 came up I'd have no hesitation buying it.
I think most people don't believe it though, I've had my sorted C4 for sale for a month now for $48k but everyone would rather buy the $30k "deal" and then spend 20 on it (plus a lot of headaches).
Originally Posted by cscrogham
This is spot on!
I'd much rather have a sorted C4 than a lower miles car that is "fine as is" - buying a "good" low miles car is a good way to spend a lot of money.
+1
