Smoking exhaust- what could be the problem? - Page 2 - Rennlist - Porsche Discussion Forums
964 Forum
Sponsored By:
Sponsored By:
Old 09-01-2016, 06:14 AM
newsboy
newsboy's Avatar
Your oil level gauge should read between one half and two thirds full, with engine warmed up and idling on level ground.
newsboy is offline
Old 09-01-2016, 01:57 PM
LM964
LM964's Avatar
Certainly overfilled, if that where your level lies while idling on a level surface. As said already, oil temp seems high too. Do you know if; a) oil is passing to your oil cooler (thermostat opens valve to front cooler @ second 8pm graduation) and b) the oil cooler fan works?
LM964 is offline
Old 09-01-2016, 11:14 PM
peter y.s pang
User
peter y.s pang's Avatar
seeing your oil stick, Certainly overfilled. For the oil temp, if it point to 9- 9:15, at that time, the oil fan should start running, so the oil temp will not going up. and once to open road, it will drop down to below 9 o'clock position. It is normal.
peter y.s pang is offline
Old 09-05-2016, 07:12 AM
tonyc
User
Took the car to the mechanic this weekend. He removed around 1/2 litre oil. The temp did drop a bit but after watching the catch idle for around 15 minutes of so, puffs of Blue smoke still appeared from time to time. He felt it something internal, perhaps the cylinders, although said it wasn't serious yet.
Not good news but finally got there. Thanks all
tonyc is offline
Old 09-05-2016, 12:28 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
If you had an over-fill, then some oil may be in the intake manifold/plenum. It doesn't do any harm and will eventually get burned off. If you want to clean it, you can remove one side of the intake and then you may find oil in the lower horizontal portion of the intake plenum. You can then wipe it out.
Rocket Rob is offline
Quick Reply: Smoking exhaust- what could be the problem?
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
