964 Forum 1989-1994
Ruf Wheel Offset Confirmation
Old 08-06-2016, 11:00 AM
993PET
993PET's Avatar
Default Ruf Wheel Offset Confirmation
I'm looking a set of Ruf wheels to install on a '93 Targa, the owner says the were made for a narrow body 964/993.
Sizes are:
Front 8.5x18 ET61
Rear 9.5x18 ET48.3
The car will be lowered with H&R Greens and Bilstein HD's
Also what tire sizes would be a good fit?
Thanks,
JF
Old 08-06-2016, 11:44 AM
911Jetta
911Jetta's Avatar
Love Rufs!
8.5 seems too wide up front,
10 will work in back.
Will let those with experience chime in.
Great article here:
http://www.world964owners.com/#!AFTE...f29542aa2a5bb4
Old 08-06-2016, 12:19 PM
crg53
crg53's Avatar
The fronts are a bit on the wide side, 8" would be better, and the offset is wrong, should be around et50. The rears should be OK.
Old 08-06-2016, 12:46 PM
993PET
993PET's Avatar
Thanks for your reply, isn't the higher offset due to the wheel being 8.5" rather than 8"?
JF
Old 08-08-2016, 08:58 PM
AMGSiR
AMGSiR's Avatar
Sizes are:
Front 8.5x18 ET61
Rear 9.5x18 ET48.3
Thanks,
JF
The offsets don't sound right.
Offset: 8,5 x 18: 58 mm, 10 x 18: 66 mm
R65 300 360 01
It is required to install steer angle limiters at the front axle (standard on the works 17'').
8,5 x 18 10 x 18 225/40 ZR 18 265/35 ZR 18
Rear 15 mm spacers
Old 08-09-2016, 08:08 AM
congaman
congaman's Avatar
For what its worth, I have the 17" Rufs and they are 8 and 9 inches wide with offsets of 56 and 47.
Old 08-10-2016, 07:10 PM
Nyeguy
Nyeguy's Avatar
Default Ruf Wheels
I have had 18" Ruf wheels on 2 - 964 narrow bodied cars (both targas). Bought new from Ruf in Dallas. This is from Ruf.wheel.pdf
Old 06-12-2017, 11:10 PM
Michael D'Silva
Michael D'Silva's Avatar
Didn't want to start another thread...
My car is a 1990 c2 manual 964...
And have come across a set of Ruf rims.. sizes and offsets
Fronts 17x8 +56mm
Fears 17x9 +44mm
Reckon they will fit?
Old 06-13-2017, 07:48 AM
Michael D'Silva
Old 06-13-2017, 08:09 AM
18T_BT
18T_BT's Avatar
The guy above you post #6 has pictures of the wheels you are looking to fit
Old 06-13-2017, 08:13 AM
Michael D'Silva
Yep, thanks.. interesting that his are listed as 47 rear offset, but the black ones I am looking at are listed as 44 offset...
Not sure if that is an indication as to whether they are genuine or not. ??
Old 06-13-2017, 08:17 AM
Michael D'Silva
Old 06-13-2017, 10:28 AM
18T_BT
18T_BT's Avatar
They should be stamped with size an offset on them if they are real. Ask the seller:
Example:
http://www.aicauto.com/content/parts.asp?Image=516
Old 06-14-2017, 12:15 AM
gouyou
gouyou's Avatar
Fronts 17x8 +56mm
Fears 17x9 +44mm
It should be 56.7 for the 8". They have a TüV certificate and were advertised for Carrera 2 and 4. Original tires would have been in 215/50 and 235/45 or 235/45 and 255/40.
Old 06-14-2017, 05:34 AM
Rstrada
Former Vendor
Rstrada's Avatar
Fronts 17x8 +56mm
Fears 17x9 +44mm
Michael,
Yes they will fit fine. However, for this particular wheel, RUF also had a 17x10 that was for the 964. What you have on the rear, 17x9 ET44, was for the 944 fitment. you will be fine running them just with narrower tires than the ideal 10'' can accommodate.
Quick Reply: Ruf Wheel Offset Confirmation
