Looking for wiring diagram of clock/instrument cluster
Hi- I want to wire up a big *** red warning light for when the alternator belt breaks, comes off, etc. so I don't cook my engine. It's a 1990 C2 race car and just need to know which pin is for the charge indicator light(battery/alternator). Thanks so much.
Hunter
Hunter
Not easy to read, but I don't know of a better scan-
I assume that you're concerned about the fan belt not the alternator belt? Unless you converted to a single pulley? In that case, you could wire up your own simple circuit that triggers a light if the voltage drops below ~12.5v.
