Convenient route for wire from frunk to cab?
I want to put a monitor on the car's battery to keep an eye on the rate of discharge while the car's sitting in the garage. I would like to put the display in the cab. I have to run something like a 4-wire telephone cable (remember those?)
Anyone suggest a convenient route for the wire?
thanks,
Dan
thanks,
Dan
No need to do that. Just buy a monitor that plugs into the cig. lighter. Mine monitors the voltage on a digital screen, and has 2 plug in ports for accessories.
IHI KING!
+1 - In the passenger footwell, there is a rubber grommet that you can slip wires through. I used it back in the '90's to run a CD changer cable. To access it from the frunk, I detached the fuse box and moved it to the side so I could reach the wire.
