Why 2 Different NGK Part #'s for Ignition Wires?
I went on NGK's website to look up the correct Part # for ignition wires for a 964...
http://www.partcat.com/ngk
... But if you put in a 1990 964, they tell you #54180, and then for a 1993 964, they show #54143...
... And they are significantly different in price, as well.
So what's the deal?
I have a '94 964 but I usually put '93 in as the Model Year when I do parts searches, so that there is no mix-up with a 993.
Not sure which wire set I should buy....
So what's the deal?
RL Technical Advisor
'89-'94 use the same part numbers; I do not use the NGK sets, however the one Beru set covers ALL N/A 964's.
I would choose the least expensive version and go for it.
Be careful if you go with the NGK, they dont have the seals, etc
Also Some of their Porsche replacement does not use the Beru Connectors so its a real pain to put the seals on when you cant remove the connectors!
