Can a 964 w/ remote starter switch (Hasn't run in 15 years)
Long story short picked up a 964 that hasn't run in 15 years. I know it's a long road ahead, looking to get an idea if I can use one of these since nothing happens with the key (new battery).
Basically looking to see if the engine has compression. Plugs pulled out of it, I am able to rotate the engine
THANKS!!!!
THANKS!!!!
Not sure how dielectric grease on the connections is helpful?
Check fuses, and DME relay, although none of that should prevent the starter from cranking. You can jump the starter by touching across both terminals with a screwdriver - just be careful not to shock yourself!
