964 Forum 1989-1994
Another tire question...
Old 05-06-2016, 03:22 PM
02m2
02m2's Avatar
Default Another tire question...
92 C2 max tire sizes street use (PS2's)
Will: 225/45/17 and 275/40/17 cause me any issues?
Car will be lowered from stock height and probably slightly higher than euro rs height.
Old 05-06-2016, 03:31 PM
Vandit
Vandit's Avatar
Tire sizes is only half the picture. What are the wheel widths and offsets? Alignment specs will affect fitment too.
Also, a 225/275 split might be a bit more understeer prone than 225/255 or some other wider front to pair with the 275 rear.
Old 05-06-2016, 03:41 PM
02m2
02m2's Avatar
The fronts are 8/17 et 45
The rears are 9.5/17 et 48
running a jrz suspension and will be set slightly higher than euro rs height.
Old 05-06-2016, 06:03 PM
Bill Verburg
Bill Verburg's Avatar
ABS wants tires that are the same or at least close to the same OD, the limit is ~5%
225/45 is ~24.8"
275/40 is ~25.6 ~2.9% difference, so w/i tolerance, but still closer is better
The next issue is the effect on over or under steer.
stock is 225/45(~25"OD) & 255/40 x17(also ~25" OD), If you like the way the car handles stay w/ that split ie 235/45 & 265/40 or 245/40 & 275/40 , for better turn in ie more over steer go bigger in front 235/40 & 255/40, more under steer go bigger in back 225/45 & 265/40, 225/45 & 275/40 is even more under steer.
as you go up in width you generally want to go down in profile to keep OD
down to a reasonable level.
lastly 275/40 x17 @ ~25.7 is a pretty tall tire w/ unfavorable impact on gearing
255/40 ~@25" is a good place to be.
Old 05-06-2016, 06:46 PM
02m2
02m2's Avatar
Bill
Thank you again for all the help. I already have the 275 on the back other wise I would switch them out to the 255 as suggested. As you can see the 235/50"s on the front are an issue. will switch those out to 225/45.
Thanks !!
225/45 is ~24.8"
Old 05-06-2016, 07:19 PM
Bill Verburg
Bill
Thanks !!
When I ran 275/40 x17 @~25.7" in back I ran 235/45@~25.4" in front, 235/40 would have been an easier fit but it runs afoul of the ABS restriction.
Old 05-06-2016, 07:35 PM
02m2
02m2's Avatar
other issue was the ps2's only come in a 235/50 so will leave the 275/40's in the rear and swap out the fronts for the 225/45's.
Quick Reply: Another tire question...
