Ohlins or KW?
PSS10, Ohlins, or KW?
adding Bilstein PSS10s to the discussion
I am trying to decide between Ohlins and KW suspensions for my wide body (America Roadster). Most of the KW feedback is positive, but Ohlins has an impressive resume.
It seems the Ohlins can be upgraded in stages up to 4-way, so although they have a higher initial cost (especially considering the current KW group buy), perhaps they are more future proof.
Any experience with both, or advice on which path to follow?
I appreciate any and all feedback.
Cheers,
Scped
Cheers,
Scped
The first question you have to ask yourself is what will the car and suspension be used for. No sense in spending that kind of $ if it's street driven only. If the car will see track use, then I would talk to Steve Weiner at Rennsport.
It will primarily be driven on the street (it is a convertible), but may be taken to the track now and then.
I know they will not be seen, but I do prefer the look of the Ohlins - for whatever that is worth. Thanks.
Several thoughts.
First, only the very best suspension people
le can properly adjust a 4-way damper. As such, whatever you chose, I would limit it to a 2-way damper.
Second, yes the Ohlins looks better but I suspect the KW units might be better for your use.
Third, you might want to also look at the Bilstein PSS10 Walter Rohrl Edition for 964.
i have cars with both.
A TTX 2 way is about 10k. Unless you have shock pots on your data system and/or a chassis engineer to adjust your dampers, stick to 2 way. I'm guessing you're not racing the car. KW clubsports are about 3.5k. They are a 2 way. KW competition are about 7k for a 3 way with remote canisters. All are rebuildable.
Both are excellent, both can be setup to work very well and be very supple yet controlled. Spring rates matter. Clubsport spring rates are pretty aggressive for street use.
But, if you want my candid opinion? Grab the MCS dampers mooty is selling. Get proper top hats and some swift springs you are set. Otherwise the KW kits are pretty much plug and play, but spec a softer spring if for street only.
90% of casual track day guys won't be able to adjust 2 way dampers either. Honestly, for a convertible that won't see serious track duty, I'd buy a quality set of single adjustable and spend the rest of the money on bushing upgrades and top hats to remove a lot of the slop from the rest of the system...
Thank you all for the feedback. I am compelled to consider the Billstein pss10s (I made an update to the title) based on the note from Robert - and the fact Walter Rohrl uses them in his 964.
fvd sells the Walter Rohrl version of the pss10s - however they state this particular version only fit on the European RS edition.
If someone can provide details, I would be interested to learn:
1) What are the significant differences between a "regular" 964 and an RS that would require different suspensions? I assume it is more than ride height
2) What are the differences between the "regular" PSS10s and the Walter Rohrl version?
Thanks again,
Scped
Thanks again,
Scped
Some of us win season championships in our cabs
scped- KW are also stainless, Bilstein very definitely are not. In case you use your car outside of sunny days. Personally, I like, and use, the adjustments options too. To answer your first question-
1. RS uses monoball top mounts which alter the overall ride height and require a shorter-bodied shock to obtain the correct height. RS coilovers on stock rubber top mounts will put you much too low.
I have used all 3 brands on a number of my previous cars. MR2, ITR, S2000, RSX, EP3, FRS, NSX, 964 and hands down if you are going to use mostly on the road with occational track then I would for with KW v3.
If anyone has questions on this im happy to help. Ive been through this fitting later cup/rs suspension and then motons to my early coupe.
