8" cups and 255?
8" cups and 255?
Hi all,
My 964C2 came with aftermarket 17" Mille Miglia Cup wheels but curiously, they are 7.5" in the front and 8" in the rear with wrongly-sized tires. So I want to put 255/40 in the rear as per normal spec and I wasn't sure if 255s were a bit too wide for 8" rears. They are 235/45 currently for some reason.
Are the OEM Cups 8" in the rear? And they came with 255/40s? Can anyone help.
Oh and.. YES I searched. But most have 9" Cups in the rear, which isn't an issue at all with 255s.
Thanks in advance to anyone who might be able to help before I order the tires.
Thanks RallyeChris I think I will have to put my rears up for sale for someone who may want to put them in the front on a Turbo or wide body, then search for proper 9" rears.
I currently have 235/45/17s in the rear that came with the car and I would like to go wider to the recommended size.
Are you sure that the rears are 8? I have the Millie Miglia wheels and they are 7.5 front 205/50 and 9 rears with 255/40 tires.
The et is stamped on the wheel.
Hi all,
for 255/40 x17 all the recommended ranges I've seen are 8.5" to 10"
the wider wheel gives best performance the narrowest best ride
@Derek911: Yup they are and the ET stamping confirms. I have no idea why the previous owner(s) have done such a think. (7.5f, 8r) Maybe this was the previous owners winter setup, then eventually put summer tires on it before the sale? Not sure.. I bought the car who didn't keep it too long so the setup is from the owner even before him.
Are the Mille Miglias still produced or is this an ebay/forums classifieds job? I will start shopping for the 9" right away.
@RallyeChris: I love the CCWs as well by the way and will have a set eventually. I would love a set in all black on my white 964, I think that setup looks awesome. But I still want the Cups first and keep them as a daily set.
Indeed. Factory RSA's had 8 inch rears with 255. That being said, I also agree with the rest of the overall sentiment that for hard driving- a 255 isn't well supported on a 8 inch wheel.... But it isn't exactly dangerous if Porsche supplied OE cars as such.
Fvd sells the wheels. They are a trusted vendor.
I also just found a few on eBay but the Et's are not right. You need 9j et 47.
The ones on eBay are et15.
http://www.fvd.de/us/en/Porsche-0/-1...ay_50/SON.html
