993 Axels
04-12-2016, 08:54 PM
993 Axels
Do 993 C2 manual axels fit on a 964 C2 manual?
Everything is pointing to a yes so just triple checking with the experts
04-12-2016, 11:44 PM
Part numbers are different. I'm wondering if they're either a different length or outer joint because of the 993 rear suspension.
04-14-2016, 07:55 PM
Well... I attempted this swap with a new set of narrow body 964 axles on a 993 and it was a
no go , way to short ...Bert
04-14-2016, 11:19 PM
^ that makes sense (way too short) since the 993 has a wider track than the 964.
Additionally, the tooth count on the ABS gear is probably different.
