964 Forum 1989-1994
18x10 et 51 in the rear?
Old 04-01-2016, 09:34 PM
dsan
dsan's Avatar
Default 18x10 et 51 in the rear?
Hate to ask this question because I normally am quite good at figuring out wheel fitments but I'm just having a brain fart I guess or getting old I know I've ran 18x10 et 47 before but I can't remember how close they were to the oil line.
Thanks for the help
Old 04-01-2016, 10:00 PM
Derek911
Derek911's Avatar
My et 50 touched the oil line... 3mm spacer made it perfect. Everyone is right, Et 47 is that sweet spot. Et 51 works with the right spacer.
Old 04-01-2016, 10:13 PM
dsan
dsan's Avatar
Kinda what I was afraid of . These are et 51 with a 7mm spacer (et 58 without) and I believe 7mm is the largest I can go without extending the lugs. O well, it was going to be a whim purchase anyway, guess Ill save the cash. Thanks!!
Old 04-01-2016, 10:29 PM
Derek911
Derek911's Avatar
I thought 18x10 et 50 would fit without a problem. I thought there were some people running et 50 on here. I put mine on and they wouldn't even seat on the hub without touching the oil line. I was prepared and had 3 mm and 7mm spacers just in case. The 3mm was on the money.
Old 04-01-2016, 10:33 PM
Spyerx
Spyerx's Avatar
Received 1,729 Likes on 1,057 Posts
My rear BBS are et 51 18x10 and clear fine. I run a 275 rear and the tire kissed the oil line so had to flatten. Rim does not hit.
Old 04-07-2016, 10:36 AM
sml
sml's Avatar
Thanks for the help
You dont need to tell us the diameter. it is pretty much irrelevant.
So your 10ET47 is your question.
Here is 10ET50 in detail ...
https://rennlist.com/forums/964-foru...40-photos.html
Old 04-07-2016, 11:15 AM
Goughary
Goughary's Avatar
Extending the lugs is easy. Not a bad job, and can be done on the car with just the rotor off.
Stock lugs are 45mm from the bottom of the head to the end of the threads. Add whatever amount of length for the spacer. Done.
If you were closer to CT, I'd do it for you cheep...
Derek911
Derek911's Avatar
[QUOTE=sml;13176962]You dont need to tell us the diameter. it is pretty much irrelevant.
If he didn't say 18 someone would still want to know.
Also, like someone else mentioned, rear camber is going to be the deciding factor on et fitment. People running an et in the low 40's most likely have their negative camber maxed out. People who want -2 or more or rear camber will need to adjust et accordingly depending on wheel width to prevent oil line rubbing.
Old 04-07-2016, 11:53 AM
964George
964George's Avatar
Here's a great website to help visualise the difference between wheel fitments http://www.willtheyfit.com/
Quick Reply: 18x10 et 51 in the rear?
