Heater blowers
Heater blowers
Hi guys, hoping you can help with a little problem.
I recently removed the engine and tiptronic box from my C2 so I could get the box refurbed. It's all refitted now and running well but I've got an odd problem. When I start the car the blowers only work for a couple of seconds then they go off. When I removed the engine I broke one of the connectors on the resistor that clips into the pipe from the fan in the engine bay so I replaced it with a new one but it made no difference to the inop cabin blowers, I'm sure it's somthing simple but I can't put my finger on it! Any ideas what I'm missing?
Many thanks
Ian
Many thanks
Ian
You most probably have a problem with the rear fan circuitry. I would bet the fans work fine at minimum temperature setting. Check the rear fan operation according to my DIY procedure crg53 kindly linked to above.
Cheers,
Tore
Cheers,
Tore
