On the one day that it rains in SoCal my wipers aren't working. They use to work fine prior to the paint job. When I install a fuse they just blow immediately. Have any of you experienced this and what was the fix?
I would unplug the wiper motor and try again. If the fuse still blows you have a loom issue, if not then the fault is somewhere in the motor/autoparking assembly.
