Oil lines to case
Thanks Cobalt.
I cleaned things up quite a bit and have all the oil lines off to be replaced. I agree, the crush washer is probably not the issue, but while I'm there, I figure might as well replace it. As the heat exchangers are off, I'm replacing the oil return tubes since it's so easy now.
I will not use anything (teflon, locktite, etc.) upon reassembly of the lines to the case.
I will be doing lots more cleaning before reassembling. I have the oil tank out and the oil line going from the t-stat to the oil filter hosing being rebuilt today. Flushing all the lines (though all but that one will be new), t-stat, tank, etc. with Naptha.
Will just have to reassemble and see what else might be leaking, though I think you are correct, there are other culprits we will discover. I think some of this might be left over from years of not being cleaned. I've already attacked the usual suspects on the topside (breather gasket, oil sending unit o-ring, breather hoses). Looked like an axle seal was leaking, so I replaced both those. PS was leaking before I purchased, and the drive gasket was replaced on the end of the cam shaft before I took possession. I don't think it was cleaned after that.
I just replaced both of there oil lines due to corrosion rather than leaky joints, however I was really surprised when the ali sealing ring came away as two pieces having corroded overs its life.
I researched the whole teflon tape idea but in the end just got the new lines and new rings nice and tight. I cleaned up the connectors marked '23' above. No leaks so far
I've got my engine out for a reseal. I will be using Permatex #2 on the oil line couplers. Have heard favorable reports from folks using them for similar applications on other forums. I will let you know how it holds up in the coming months.
