964 Forum 1989-1994
Ducktail install question
Old 02-19-2016, 03:02 PM
DobermanDad
DobermanDad's Avatar
LOL!
Couldn't help myself.
Have you seen the Rothsport for the front hood? I might try to make something like that.
Old 02-19-2016, 04:03 PM
SJJ28
SJJ28's Avatar
It may be a lot of time and effort, but those good shocks come in millions of sizes and pressures...id bet you could find some thy would work for the right length and weight of this deck lid!
Old 02-19-2016, 04:28 PM
DobermanDad
May sounds strange, but some worn out ones may work perfect with a ducktail.
Old 02-19-2016, 10:04 PM
spartansix
spartansix's Avatar
I am using only one shock/support on my Stratton Ducktail
Old 02-19-2016, 11:46 PM
PNine64
PNine64's Avatar
Huh...I was wondering if it would be lighter. Thanks!
Like your badges too.
Old 02-20-2016, 10:16 AM
tdiquattro
tdiquattro's Avatar
That is a factory part, and not expensive!
about 30 dollars with the pivot and a clip that holds it out of the way when closed. (you can just see on the pic about half way down)
964.511.551.00 rod for frunk £5
964.511.569.00 pivot £13
999.507.372.07 clip when shut £2
Old 02-20-2016, 10:46 AM
biggynuts01
biggynuts01's Avatar
Thanks for the idea. I think im gonna buy this.
Old 02-20-2016, 12:14 PM
DobermanDad
Yeah, but the Rothsport prop is for the frunk, I need something for the lid.
Old 02-20-2016, 01:15 PM
biggynuts01
After reading this discussion. I reinstalled one of the weaker/older shocks that I had and rearranged my shims. Now the trunk sits pretty flush and seems to operate pretty well.
Old 02-20-2016, 10:16 PM
DobermanDad
What's the easiest way to center the lid.
Old 02-21-2016, 12:11 PM
DobermanDad
I ended up using on shock and it works good. Are there tricks to getting this thing centered? It's off about 5mm to the left. Kinda annoying actually. Thought about drilling the bracket holes larger to give me more adjustment, but don't really want to go that far.
Old 02-21-2016, 06:32 PM
Streetdaddy
Streetdaddy's Avatar
Pics please!!
Old 02-21-2016, 08:38 PM
spartansix
spartansix's Avatar
Shims! Make a bunch of thin (1/32) shims with holes drilled for the decklid and start adding them to one side or another. Rob & I spent an hour or so one day getting mine aligned just right.
Old 02-21-2016, 10:29 PM
DobermanDad
I had to run a shock in the right and make a custom shim for the right. Still have to move the tail about 3mm right:
Old 02-21-2016, 10:57 PM
spartansix
spartansix's Avatar
Yes, I also have only the right shock installed. We ended up with shims on both sides.
Quick Reply: Ducktail install question
