FS: Brand NEW Bilstein HD Shocks for 964
interesting. The konis are flush. My RSR were monoball. so there were misalignment spacer between the shock and trailing arm. I don't think these will post problem.
The rubber bushing on bilstein HD will flex, as well as your top rubber mount.
bilstein HD vs monoball.
The HD's are a good deal.
I don't know a mono-ball from a botchiball . Perhaps a pic of two struts sold under exactly the same p/n will help describe my issue;
Bottom mount protrusion (bottom strut) is what I was sent, no good .... Need flush mount (top strut in pic) .
Unless it is a visual problem for you either shock should do the same thing.
Pls see my concerns in my C4 strut thread. I want to solve my issues outside Mr. FlyT's sale thread. Sorry for the Hijack.
Update:
I am installing exactly what is for sale here. Bilstein confirmed to Tirerack that all is good on rear installation questions I had. Can use existing OEM washer or I could replace with smaller diameter washer that covers steel bushing.
This is a good price for the set, I paid closer to 1k.. Cheers!
Update:
At first glance I wanted these, but then realized they were for newer 964 not my old 90 styles rear dampers.
Do these come with springs by chance? If not, then you overpaid at Tirerack.
