Buy or Run?
Buy or Run?
Hi Folks,
I am in the middle of negotiations for a 1990 Carrera 4 (see car below) and need to decide to proceed to a PPI - what do you think?
http://www.luxurysportautos.com/deta...-14370733.html
1-owner, Clean CarFax
Any help would be appreciated:
Brian
Brian
looks clean. i dont see anything that would make me run. would be nice to know if they are selling the car or consigning it because that would help with your negotiations.
I had some help from a local Rennlist member and he provided me the following "drive by observations for the 1990 Carrera 4:
Originally a Canadian car imported to US in 1993 andserviced locally in Portland, OR. No noticeable dings in the body panels; noapparent repaint.
EXTERNAL
- Not so professional touch up of rock chips on hood. Lots of little blobs. (Picture)
- Smile is straight but there is some underbody damage. (Picture)
- Topside of engine behind the cooling fan is bone dry. Cooling fan has some corrosion. (Pictures)
- Motor mounts are shot. (Picture)
- Car is fairly damp underneath but not dripping (Pictures). Probably lack of gaskets on the heads and the typical timing chain leak. Does not look like the case seam is leaking.
- Light rust on engine tin.
INTERNAL
- Seats show a fair amount of creasing but leather is tight (no picture).
- Dash dials are super clean, no cracks or flaking. Plastic gears on speedometer may need to be rebuilt however.
- Clutch may need replacement (engaging high on the throw).
Maybe most issues are due to lack of use?
B
Go ahead with the ppi. Looks like she is a good buy based on what is written. I would also google the company selling it on rennlist and pelican. I purchased from someone else based on some feedback on the boards about that company.
Definitely get a proper ppi done. When i was looking i had dealerships do proper ppi from accross the country. Saved me making a few big expensive mistakes.
+ 964 on the PPI. The current market doesn't seem to favoring those buyers who hold for a PPI, but if you can stay in the hunt for this C4, definitely do it. We aren't talking about a 15k steal of a deal here, so make sure you know what you are getting into. All that aside, it does look clean.
Car looks pretty clean but agree some of the issues are from low usage.
Pay for a PPI with compression/leak down and to investigate the real source of the oil leaks. Budget appropriately. If basic gaskets and seals, not a big deal. If cylinders.... $$$$
The front pan dent will need to be addressed, and since this was a canada car more thoroughly investigate any corrosion issues.
This is pretty strong $ and to me assumes very few things need real addressing i.e. the big $ stuff is handled.
It is really hard to find a truly great car. This one is priced like a great car, but falls a little short. Not saying it can't be great, but all the fixes needed should be in the negotiating.
Possibly a clutch? New set of tailights? Fixing the leaks? Repairing the rusted tin? fixing paint? All potentially over a thousand dollars, and potentially much more. No one wants to show off their new toy and open the hood to rusted tin and a corroded fan.
It is hard to describe a great car, and some people never really see the difference. Low miles doesn't make one great, an owner that never lets ANYTHING go unfixed and is proactive with the maintenance and care does. My dad has a mid 90's Impala SS with three times as many miles that would make this car, and my 911 also, look like an unloved rental. If you are a person that sees the difference, negotiate to fix everything, or keep walking
^^ Think that's easier said than done, particularly with the limited supply of 964's. Also, there are so many unknowns it's an exercise in futility to try and negotiate "possibilities". If you try that tact, you can be sure to never actually end up with a car...
Strong money for a 90 C4 in basic color combo. Top side looks decent although they are claiming original paint. Obvious areas need to be addressed. Engine is probably original and with the oil could possibly use a top end.
You could low ball them and wave a PPI or offer $49k and give yourself a backdoor that if any panel is painted or engine needs a rebuild you can walk.
The rest is typical. In fact I would expect more rust on the engine tin and corrosion on the fan and housing if the car was mistreated or used in harsh salty winters.
The rest of what I see shows that the car seems to be a low mileage car. Hard to tell nowadays there are so many with false odo readings.
Buy on condition not miles. The rust you see may only be the tip of the iceberg. I'd be curious to see the typical areas around the windshield and fenders.
C4 from Canada is an all-year car back when it was new for sure.
I'm not saying this car isn't worth it. It's a driver quality car that needs some love. All depends what your pain tolerance is ultimately
